The 10SI is indeed "easy to come by". It was used in virtually every GM car and light truck from the mid-70's through the late 80's.
Regarding the 300 wiring you are correct - it is only a little more complex than an H/M. The most significant difference is the 300 has a key ignition/start switch - thus the addition of a solenoid to the starter circuit.
Today's Featured Article - Product Review: JB Weld - by Staff. JB Weld is basically an epoxy glue that does an exceptionally good job of bonding to cast iron and steel along with several other materials. As I mentioned, it is so common that I have yet to buy a tractor that did not have JB Weld used somewhere. It is sometimes used so well you can't tell its there and other times used as a sloppy quick fix. Finding where and how it can be used correctly is key to whether you are using it as an "inelegant hack" or an integral solution to difficult and expens
... [Read Article]
Latest Ad:
[More Ads]
