Farmall Tractors Discussion Board
1949 cub hydraulics
Posted by JD on March 15, 1999 at 07:22:51:
I have a 49 cub with a woods mower on it. When I raise
the mower deck, it jumps up and down after it has reached
the height where it is set. Is there a check valve sticking
or is there some other problem that could be causing this.
Also, it seems to put more of a load on the engine when I
lower the deck than when I raise it. Could this be the
result of the same problem? Any help would be appreciated.
Post a Followup
: Re: 1949 cub hydraulics
