Re: Oil leak at rear axle housing
Posted by K-Mo on January 07, 2002 at 19:28:46 from (65.169.189.2):
In Reply to: Oil leak at rear axle housing posted by GooseCreek Frams on January 07, 2002 at 16:40:43:
Bolt your axle housing back to the transmissoion housing and start over (you can leave the bolts out of the bearing retainer). You forgot the bull gear.
I don't remember if you can remove the bull gear through the PTO hole or not. Usually the platform is removed from the transaxle. Either way get access to the bull gear and remove the bolt holding the bull gear to the axle. I used to screw the bolt back into the axle without the big washer. Then place a piece of material beween the bolt and the other axle. Then screw the bolt out to push the axle out of the bull gear. After the axle is removed the axle housing will come off.
Post A Followup
: Re: Re: Oil leak at rear axle housing
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
