Re: Re: Spark Plugs 6 V verses 12V
Posted by vern on January 17, 2002 at 22:41:07 from (216.201.10.236):
In Reply to: Re: Spark Plugs 6 V verses 12V posted by Larry on January 17, 2002 at 21:33:48:
6v or 12v or 24v system---the coil sends the same voltage to the plug-----that is what the little square porcelin unit is on many coils---if you have a 12 volt system but a 6 volt coil (as on my 504) the porcelin unit shunts some of the voltage so the coil only receives 6v
not sure about magnetos---never worked with one
Post A Followup
: Re: Re: Re: Spark Plugs 6 V verses 12V
