Cracked block on C-113, Farmall A
Posted by Tom Fleming on March 17, 2009 at 16:33:29 from (67.20.241.112):
Well, I probably already know the answer, however, I thought I would ask anyway.
bought a parts A that was not running, but the engine was not frozen, and turned freely. No coolant in the oil. No oil in the Rad. external block is intact, and no cracks.
Get engine off the tractor and start to dismantle the engine. all is well until I get the head off. Find a crack through the water jacket holes on the carb side of the block. It starts at the back of #1 and runs ziq-zag through the water jacket holes to the front of #4. No ridges on the sleeves, and VERY VERY little wear.
Now the dilemma. Is the block junk? is it ok to run as is? Should I try to have the crack ground out, and welded, then machined down? cylinders were clean. no rust.
It appears that the engine was running fine, with no leaks.
I will try to post pics a bit later.........
