Farmall Tractors Discussion Board
Re: Age of a Farmall B
Posted by Stan(VA). on April 10, 1999 at 04:01:56:
In Reply to: Age of a Farmall B posted by Three B's on April 09, 1999 at 19:06:36:
The P on the transmission case would be right for a '46. I have never seen a casting with a numeric year as you report for the final drives. The engine appears to have been replaced from a '52 Super C. That block has the larger sleeves for 3 1/8" pistons as opposed to 3", and if you look just below the distributor you should see a cutout for a hydraulic pump which the original A and B motors don't have. Sounds like the same setup I have. I just put a Super C block on my '46 B to add hydraulics to it.
Stan(VA).
Post a Followup
: Re: Re: Age of a Farmall B
