Farmall Tractors Discussion Board
H Farmall advice need some
Posted by John Walker on April 11, 1999 at 15:08:10:
I've had fairly good luck with a cobbled together 3 point hitch for my H, would be glad to share ideas. My problem. My H won't start with the choke all the way out, won't run with it all the way in. After about an hour of hard work starts sputtering and getting weaker, I can limp it along playing with the choke some but eventually it dies and after setting a long time will run again and repeat the process. I've had the carb rebuilt at the dealer, new plugs, wires, points, etc. The problem is in that darn carb somewhere, but i can't find it. John
Post a Followup
: Re: H Farmall advice need some
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
