Farmall Tractors Discussion Board
Re: Re: Gearlube / brake leaks
Posted by The Red. OUCH! You would remind me of that Bull Cage. on April 17, 1999 at 10:46:03:
In Reply to: Re: Gearlube / brake leaks posted by justin on April 17, 1999 at 09:44:21:
Justin you would remind me of that bull cage. Didn't know that when I replaced the seals on the 46H at the farm several years ago. I still have a piece of bull cage down in the transmission with a few loose balls from a broken bearing. You are correct. When I replaced the one bad bearing and stuck in new seals, leaking problem quit.
Post a Followup
: Re: Re: Re: Gearlube / brake leaks
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
