Farmall Tractors Discussion Board
Re: Gearlube / brake leaks
Posted by justin on April 17, 1999 at 09:44:21:
In Reply to: Gearlube / brake leaks posted by Dick Davis on April 17, 1999 at 05:32:31:
Do like Red said when replacing the seals.. One thing which you should check, are the internal bearings which support the shaft.. There is a chance that the seals have worn a groove in the shaft, but usually when a seal goes bad directly after replacement, it is because the bearings are bad, and the shaft isn't being supported in the manner which it should, thus letting the shaft fall lower on the seal.. IF you do need to replace the bearings, that will mean that the deck plate needs to come off, and the axles need to come out. If you do have to go this route, it would be wise to check and see if the main shaft is loose (you can check this by just seeing if you can pick it up just a bit)... I know the further you go, the more money it will cost, but believe me, it is well worth it.. good luck
Post a Followup
: Re: Re: Gearlube / brake leaks
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
