Farmall Tractors Discussion Board
Re: Re: Re: Oil Consumption
Posted by RK Smith on April 20, 1999 at 06:18:20:
In Reply to: Re: Re: Oil Consumption posted by H-Fan on April 20, 1999 at 06:01:39:
I admit reading your first post too fast. What oil consumption? If you drained out "to empty" 5 quarts, and put back 5 quarts, you started out 1 quart low. You haven't told me anything yet indicating oil consumption. Operate the tractor and keep close tabs on the oil level. Park the tractor in the same place each time you check. Later, if you suspect oil consumption, you can check the compression. If you are using oil, putting the tractor under load or operating at high throttle will accelerate the oil consumption.
Post a Followup
: Re: Re: Re: Re: Oil Consumption
