Re: Live hydraulic pump on a '47 M?
Posted by gots-2-go on February 18, 2007 at 18:34:18 from (69.72.56.240):
In Reply to: Live hydraulic pump on a '47 M? posted by Nebraska Kirk on February 18, 2007 at 18:12:12:
Kirk,
I belive that the change was made in the latter part of 1950 or the beggining of 1951.
The M&W Gear Company made a live pump that would bolt right on to a Farmall M without any changes required to the front cover or the timing gear.
There is a M&W pump on ebay now, it is listed for a Farmall W-9.
This pump should also be the same one that was used on the M model as well, JUST make sure that the W-9 was not a diesel model (they turn in the opposite direction).
The link to the auction is attached below.
As of this posting the reserve has not been met, and I don't know what the sellerset it at.
gots-2-go
