Re: M Farmall Problems
Posted by El Toro on February 25, 2007 at 16:53:17 from (152.163.100.199):
In Reply to: M Farmall Problems posted by waynek on February 25, 2007 at 16:37:23:
Can you turn the engine if you disengage the clutch? Sounds like something is binding in the
clutch or gear train. I would pull the plugs just to make sure there's nothing in the cylinders
causing a lock. You may need to split the tractor again. Hal
