Farmall 300 questions ???
Posted by Sam F. on February 25, 2007 at 19:54:46 from (67.150.111.220):
Farmall 300 with serial #28044. It does use a 12 volt with negative ground , am I correct ?? What is the hitch called with the bars that slide in and out easily on lower arms ?? Fast hitch ?? Is there any articles on Torque Amplifiers ?? I don't even know what they do. Where can I get the bearings and races for the front single tire axle hub housing ??
