Re: Farmall A No Start!
Posted by Roger Mills on February 26, 2007 at 07:49:35 from (71.213.68.215):
In Reply to: Farmall A No Start! posted by plh_in on February 26, 2007 at 04:33:13:
What did the shop find with the starter? Is it the original 6v starter? It should spin hard and fast with 12v on it. You said the solenoid clicks so the ignition wireing is OK. Starter does not care about polarity-spins the same direction regardless. Use a jumper cable from the high post of the battery to the starter side of the solenoid-starter should crank like a bat out of ****. If so-Jay is right, the solenoid contacts are bad. If not-and no spark, check the ground of the battery AND the starter case!! Also make sure you get a 12v solenoid or you can melt the coil inside and that can jam the plunger, won't click even when wired right.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
