Re: Gen to Alternator conversion wiring question (
Posted by JayWalt on February 26, 2007 at 12:01:52 from (70.226.7.125):
In Reply to: Gen to Alternator conversion wiring question (3 wi posted by Nawlens Gator on February 26, 2007 at 08:14:17:
Jim is right, to further elaborate, this wire needs a "switched" power from the battery. This is accomplished by connecting it to the same terminal the coil is connected to on the switch. When the switch is in the run postion, power will go to the coil and also to the alternator which turns it "on".
