Re: 300U 12v Conversion Done!!
Posted by Bob on March 02, 2007 at 22:07:57 from (69.178.229.154):
In Reply to: Re: 300U 12v Conversion Done!! posted by JayWalt on March 02, 2007 at 21:56:44:
Only a slight amount of current is needed to start the charging process ("excite" the alternator).
Once the alternator "excites", it (internally) provides it's own field current, and the external power is no longer needed.
Furthermore, the regulator in the CS series is "smart", more or less shutting of the field current "at rest", then slowly "ramping up" field current after startup, as opposed to some older designs that draw full field current even "at rest" if the key is left on.
