Re: Water in steering gear?
Posted by chadd on March 06, 2007 at 09:43:07 from (155.92.32.32):
In Reply to: Water in steering gear? posted by Glen Wentzell on March 05, 2007 at 19:58:35:
It doesn't sound like the steering box is the problem to me. It sounds like the power steering assist cylinder was damaged by water in your hydraulic system. The steering box has only gear oil in it. If it froze, I would think that it would never break loose. If the actual steering box is good, when you turn the steering wheel, the arm coming out of the side of it should turn at the same rate and at the same time. If the sloppiness is in there, then you will be replacing a roller that runs in a groove cut into the shaft your steering wheel mounts to or replacing shaft bearings. If that is okay, then the cylinder or the valves for it have been damaged due to the expansion of water as it froze. If the tractor made whining noises and wouldn't steer when started but would slowly loosen up as the tractor ran, I would be almost positive that it was caused by the ice in the relief valves and other parts of the hydraulic system. You will definitely want to get it out of there soon. Our 806 had the hydraulic oil filter housing cracked by ice in the filter housing. This caused the ice and cast iron shards to be run through the aluminum pump because it was after the filter. Needless to say, the hydraulic system isn't as strong as it used to be. Get that water out before it causes more damage. Also, try to find out how the water got in in the first place. Here is a picture of what it did to the filter housing:
Home
| Forums
Today's Featured Article -
Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
