Re: C Hydraulic Pump Problem
Posted by Janicholson on March 12, 2007 at 06:27:30 from (199.17.6.122):
In Reply to: C Hydraulic Pump Problem posted by TimBeltz on March 12, 2007 at 06:15:05:
If the endframe of the pump is not worn where the shaft goes through (housing as the bearing) it can probably be fixed. If the shaft is not grooved where the Oring rubs, a new high quality BunaN or synthetic Oring will fix it. If the pump shaft is grooved under the location of the Oring, it might be possible to have a slightly larger (maybe metric or teflon based)Oring put in that tightens it up. Another option ids to machine out the housing and put in a regular seal in a little different spot to avoid the groove. Or a speedy sleeve could be used to cover the groove, but the Oring groove must be machined deeper, and the ID of the oring shaft hole made larger to accomodate the speedy sleeve. The sleeve must be placed on the shaft after assembly or the shaft won't fit in the end bearing. Good luck, JimN
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
