Re: C Hydraulic Pump Problem
Posted by El Toro on March 12, 2007 at 06:53:01 from (152.163.100.199):
In Reply to: C Hydraulic Pump Problem posted by TimBeltz on March 12, 2007 at 06:15:05:
third party image
You probably have a groove worn into the pump shaft where the seal (No.4) rubs the shaft. A speedi-sleeve from NAPA and new seal will probably fix the problem. Hal
