Re: Replacement Block for Super A
Posted by Hugh MacKay on March 14, 2007 at 19:40:59 from (209.226.106.93):
In Reply to: Replacement Block for Super A posted by Hartford Manning on March 14, 2007 at 18:53:39:
Hartford: The block 354898 R1 is from one of 2 tractors. Super A after serial number 310000, or any Super C. FCM indicates it is from Super C and will take SC pistons and sleeves. The water pump will work, but you will need some modification for top rad hose. Everything else will bolt up or fit.
You could also order a kit for SA after serial number 310000. SA will be 3" bore. SC will be 3-1/8" bore. You can use the water pump which ever way you go, just make sure you get the head gasket for water pump.
