Magento Problems?
Posted by Redmike on March 19, 2007 at 06:16:02 from (12.183.157.34):
I have a 1940 H that was running fine until the other day when it started to sputter a little and would not throttle up very good. Shut it down and checked out the carb, drained a little gas out and generally just looked at things. I tried to restart it and it would not. Checked the spark and found it to be weak, could barely see it. Changed the condenser thinking it was bad, no difference. (Condenser is new)
Question(s) are What could be wrong, How to fix it and Is a Fairbanks Morse model X4B11 a correct magneto? Haven't had this tractor but a couple of months and always has started easy. Now won't even act like it wants to start. Just turns over.
Thanks for any help, new to this tractor and this forum.
