Re: Super MTA - 400 shifting forks
Posted by D Slater on March 19, 2007 at 18:09:15 from (64.12.116.71):
In Reply to: Super MTA - 400 shifting forks posted by 460anger on March 19, 2007 at 17:15:42:
Shift forks are the same with same IH # on them, but the forks are welded to the shift rails. 400 and MTA transmissions are the same but on a 400 top cover the shifter opening is closer to rear of tractor so slots for the shift lever in the rails is a longer distance from the fork than a MTA rail. Also if I remember correct some of the half moon cut outs in the rails for spring loaded balls are in the wrong place.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
