Run a two way cyl. from Lift-All pump?
Posted by Brad in WI on March 23, 2007 at 00:48:47 from (69.23.67.218):
Is it possible to plumb in the Lift-All Pump off of an M to work a two way acting cylinder. I do not have the extra money to purchase a hyd. valve right now and I would like to test some implements that I have. What would be the best way to do it so I could just try it. I am thinking a line from the pressure side of pump to the cyl. and the other line from cyl going into the fill tube on pump. to retract the cyl. I would have to switch the lines but at least I could try it to see if it works.
