Re: What is this for
Posted by georgeky on March 28, 2007 at 13:54:36 from (64.12.116.71):
In Reply to: What is this for posted by 1941 farmall a boy on March 28, 2007 at 13:16:47:
Check row planter uses stakes and a spool of wire with knots on it to plant corn in a pattern that allows cultivation from any direction. no matter where you look across the field rows will line up. You didn't get many plants per acre this way. I am not sure that is what you have as I am not to familur with these. I have a check row planter for a C but don't have all the pieces.
