Re: Farmall 'H' Clutch Help Needed
Posted by MN Scott on March 31, 2007 at 19:22:54 from (206.9.216.93):
In Reply to: Re: Farmall 'H' Clutch Help Needed posted by Joshua Lawton on March 31, 2007 at 16:50:03:
As your clutch wears the fingers will move at more of an angle to the rear of the tractor. Thats why you have to adjust the clutch linkage from time to time to get more petal free travel. With a new clutch you will have to lenthen the clutch rod between the petal and clutch arm to take up the space you no longer need with the new clutch. To make it simple if you have not already done so adjust the clutch linkage rod so you have about 1 inch of petal free travel.
