Re: Worksaver Cyl. Length? (pic)
Posted by Blue3992 (N Illinois) on March 31, 2007 at 20:05:12 from (172.129.101.196):
In Reply to: Worksaver Cyl. Length? (pic) posted by James in MD on March 31, 2007 at 14:29:10:
I think the Worksaver hitch that fits the H and M had a 3x8 cylinder, as in 3 inch bore by 8 inch stroke.
If you search the web, I think worksaver still has a site out there for more info.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
