Worksaver Cyl. Length? (pic)
Posted by James in MD on March 31, 2007 at 14:29:10 from (128.175.252.152):
My dad and I began installing a used Worksaver (I think) 3pt hitch on my H today, and would like to know what length cylinders should be used? I have 2 - 2" cylinders with a closed pin center distance of 22 1/2". What cylinder length came with these hitches?
third party image
We mounted the original drawbar over the hitch brackets but it severely limits how far the lift arms will drop. We are thinking of making another drawbar that will not impede the lift arm drop. Does anyone here use a Worksaver with their drawbar? Thanks.
third party image
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
