Re: Low oil pressure or not?
Posted by Steven@AZ on April 02, 2007 at 15:49:58 from (216.67.213.217):
In Reply to: Low oil pressure or not? posted by JayWalt on April 02, 2007 at 13:16:21:
10psi per 1000 RPM is a general rule of thumb... so any old 4-cylinder Farmall should be just fine with around 20 psi at full throttle.
The relief valve should be set for 75 psi in everything from the H through 450. Mine will peg the gauge all day long, comes down to about 60 idling when hot. That is with about 125 hours on the overhaul, though.
Your engine should be in good shape for many years. Probably want a new thermostat that's at least 180 degrees to prevent unnecessary wear from running too cold, though.
