Re: Loader cylinders bleeding down
Posted by Bob on April 03, 2007 at 09:29:10 from (69.178.229.154):
In Reply to: Loader cylinders bleeding down posted by Gary in Mozarks on April 03, 2007 at 09:18:54:
A worn; leaky "cup" in even one of each pair of cylinders will allow oil to slowly slip from one side of the piston to the other; letting the loader "sag".
Or; the control valves could be worn out.
