Super C Throw-out Bearing
Posted by Peabody on April 04, 2007 at 08:36:24 from (66.168.231.218):
For some time now, my Super C has made a sort of wobbling/vibrating noise when pulling off in reverse while letting off the clutch pedal. Recently it began doing it pretty badly when pulling off in any gear. I assume the throw-out bearing I replaced a couple of years ago has gone dry. I greased the bearing carrier through the hole in the SIDE of the bell housing. My maintenance manual indicates a grease fitting on the bearing accessible through the inspection hole on the BOTTOM of the bell housing, but I can't see a thing up in there to indicate there is a grease fitting. What am I missing? Where else do I need to look?
