Re: Super C Throw-out Bearing
Posted by Owen Aaland on April 04, 2007 at 19:12:54 from (65.165.246.155):
In Reply to: Super C Throw-out Bearing posted by Peabody on April 04, 2007 at 08:36:24:
Clutch release noise will start when the bearing touches the release levers when pushing the pedal forward. The noise will continue until the clutch is completely released and free play is established.
Pilot bearing noise will start later in the cycle and end earlier. It will begin when the clutch is completely released and end as the disk starts to spin with the flywheel and pressure plate assembly. It will disappear before the clutch is completely released.
Clutch disc problems will appear when the clutch is starting to engage and usually is gone when completely engaged. Oil or grease on the friction material can cause noise and jerky action before it gets so bad thet it slips. A leaking rear main seal or too much grease on the release bearing can cause lubricant to get on the lining.
From your description of the problem my, first guess would be a lining problem. If you can get at it, you could try holding the clutch down and, with the engine running, spray carb or brake cleaner on the disk in front ot the release bearing.
Today's Featured Article - A Question for Dads This recent topic from the Tractor Talk discussion board is being highlighted because it is an awesome display of the caliber of individuals that have made this site their own. The young person asking questions received positive feedback and advice from total strangers who "told it like it is" with the care many reserve for their own kids. The advice is timeless... so although it isn't necessarily antique tractor related, it will be prominently displayed in our archives to honor those who have the courage to ask and those who have the courage to respond in an honest, positive manner. ... [Read Article]
