Re: losingcharge
Posted by Owen Aaland on April 07, 2007 at 22:00:10 from (65.165.246.155):
In Reply to: losingcharge posted by dustin 47 m on April 07, 2007 at 20:38:17:
Next time you use the tractor enough to get the battery charged, remove a battery cable when you shut it off and then see if the battery is OK the next time you need it.
