losingcharge
Posted by dustin 47 m on April 07, 2007 at 20:38:17 from (66.79.88.255):
my m has an 8 volt battery i have to bump start it at first then after a while of running it will start after that is my battery bad or should i check something that could be draining the battery thanks
