Re: 160 degrees on a C-123 block! :)
Posted by Patrick Martin on April 07, 2007 at 22:50:45 from (64.154.26.250):
In Reply to: Re: 160 degrees on a C-123 block! :) posted by Patrick Martin on April 07, 2007 at 22:47:24:
"As long as the coolant isn't boiling; you're not going to hurt the engine. Getting the temp up into the 180 to 195 range is BETTER for the engine than running cold.
Yep I know it needs to be hot to maintain combustion but I wasn't sure what the parameters of this cooling system were. I wish I could find an IH specified temp range for this little engine. :)
