Re: 160 degrees on a C-123 block! :)
Posted by Patrick Martin on April 07, 2007 at 22:47:24 from (64.154.26.250):
In Reply to: Re: 160 degrees on a C-123 block! :) posted by Bob on April 07, 2007 at 22:40:53:
"I hate to tell you but the "chugging" of smoke out the crankcase breather is MUCH more likely to be sneaking past a piston than past a valve guide."
You're right Bob! I forgot about the bottom end! It could be possible I broke a ring. Hmmmmm?
Now I did do a compression check the other day and got 90psi across all four. I didn't do a leakdown check though.....Guess I need to do that tommorrow. :)
Today's Featured Article - An AC Model M Crawler - by Anthony West. Neil Atkins is a man in his late thirties, a mild and patient character who talks fondly of his farming heritage. He farms around a hundred and fifty acres of arable land, in a village called Southam, located just outside Leamington Spa in Warwickshire. The soil is a rich dark brown and is well looked after. unlike some areas in the midlands it is also fairly flat, broken only by hedgerows and the occasional valley and brook. A copse of wildbreaking silver birch and oak trees surround the top si ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
