Re: losingcharge
Posted by John T on April 08, 2007 at 07:53:18 from (66.244.90.5):
In Reply to: losingcharge posted by dustin 47 m on April 07, 2007 at 20:38:17:
In regards to whether or not a 6 volt genny will charge an 8 volt battery, the answer I believe is IT DEPENDS::::::::::
1) If the charging system just uses a simple 2 wire Cutout Relay system IT LIKELY CAN
2) If the charging system uses a Voltage Regulator having ONLY a current control relay (in addition to the normal cutout relay) IT LIKELY CAN
3) If the charging system has a Voltage Regulator that has a voltage control relay IT LIKELY WILL NOT UNLESS THE VOLTAGE CONTROL RELAY IS ADJUSTED/TWEAKED
Anyone agree or disagree???
Happy Easter yall
John T
