Re: Purchased a farmall H. Disgusted
Posted by old on April 08, 2007 at 13:14:25 from (4.244.57.230):
In Reply to: Purchased a farmall H. Disgusted posted by Should have bought green on April 08, 2007 at 12:16:45:
Theres not an engine made that will run unless you do the right stuff to them when they need it. You say it fires on 2 cylinder but not the other 2, well that means you need to do the TLC not complain that it doesn't run. Sounds like you have a bad cap and or rotor, a full tune up will go a long ways and even if its green you would still have to do the same stuff to them to keep one running as it should
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
