Purchased a farmall H. Disgusted
Posted by Should have bought green on April 08, 2007 at 12:16:45 from (71.251.161.137):
Maybe because it is cold is why it wont fire. I put 4 new plugs in it and a rebuilt carb. It fired a couple times but wont run. It floods the plugs even with the gas valve off. It spit and sputters al ittle but wont take off. It ran when drove into the shed beautiful. Any ideas. The cam is rolling, the valves are good. Lots of compression. It doesent have spark on the middle plugs. It does have good spark on the outer two plugs. Should do something more shpuldnt it?
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
