Re: Purchased a farmall H. Disgusted
Posted by Tom Windsor on April 08, 2007 at 15:45:05 from (69.40.47.109):
In Reply to: Purchased a farmall H. Disgusted posted by Should have bought green on April 08, 2007 at 12:16:45:
I have read your note. Don't get your underwear in a knot. The problem presented is simple, have patience. You most likely have one of two problems...wires crossed or a bad distributor cap. The firing order is stamped on the engine on the side just behind or to the rear of the generator. Trace your wires and make sure they are hooked up in proper order starting with #1...which is up front #4 is in rear. Take the distributor cap off and tap the starter and note the direction of rotation of the rotor button. Then check your wires beginnign with #1 in the same direction as the rotor rotates. The second wire should go to cylinder #3, the third to #4 and the 4th to #2. If the wires are correct, take the distributor cap off and check it closely for cracks and moisture--even fire ants...Make sure the contacts and the rotor are not burned up. If you see problems, replace the rotor and cap. Lastly, if all of the above checks out, I would then consider fowled plugs and bad plug wires. If you go through all this and get it correct, It will run. TW
Home
| Forums
Today's Featured Article -
Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
Latest Ad:
1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
