Congratulations!
Posted by A. Bohemian on April 08, 2007 at 15:55:57 from (207.170.88.231):
In Reply to: Cub Charging Problem posted by AlexLV on April 08, 2007 at 15:39:55:
Quote: "It has the original 6v starter and generator, but it has a 12v battery and lights." Are you sure? If so, congratulatons, you have a set-up I"ve never encountered before. Did you do the conversion yourself? If not, can you be sure the 6 volt generator was not replaced by a 12 volt model? Quote: "The problem is, the battery is not being charged when the tractor is running." Watch the ammeter. If it shows more than about five amps, the generator is charging the battery; but a six-volt generator is unlikely to properly charge a twelve-volt battery. Get a voltmeter and check the votage at the battery terminals while the ammeter shows the voltage regulator is allowing the high rate of charge. Seven volts or so? You DO have the original six-volt generator, and need to make a decision about whether to to a REAL twelve-volt conversion or not. Fourteen volts or so? Some one replaced the six-volt generator with a twelve volt one. You have some other problem, perhaps a bad battery.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
