Re: NOW WHAT? SEAL LEAKS.
Posted by georgeky on April 12, 2007 at 21:14:25 from (205.188.116.138):
In Reply to: NOW WHAT? SEAL LEAKS. posted by JFAVOR on April 12, 2007 at 19:54:38:
Is it leaking at the shaft or is it leaking from under the pulley unit, were it meets with the tractor. If you are talking about the output shaft you can't just pull it out it has to be taken apart to remove it. There is a gear and bearing on the other end of it, that is accessed by removing the entire unit from tractor. The seal should be able to be replaced from the end towards the pulley.
