Re: NOW WHAT? SEAL LEAKS.
Posted by JFavor on April 13, 2007 at 01:06:15 from (152.163.100.197):
In Reply to: Re: NOW WHAT? SEAL LEAKS. posted by georgeky on April 12, 2007 at 21:14:25:
I'm talking about the seal on the output shaft next to the pulley. I was able to remove the shaft by removing 3 bolts. Tapped on the pully flang and it slid out. But it has a gear that drives it on the end and two large bearings. haven't figured out how it comes apart.
