Re: Service valve
Posted by the tractor vet on April 13, 2007 at 08:51:43 from (75.19.122.21):
In Reply to: Re: Service valve posted by JTinNJ on April 13, 2007 at 08:14:35:
If it is a remote that is stuck try this on the pack you will see a small round plug ( if it has not fallen out ) it will pop out as it is just a push in cap use a small screwdriver this will give you access to the unlatchen screw using a flatblade screwdriver back the screw off a littel bit by turning counter clock wise and see it this will let it unlatch also remove the cover on the ft. below the seat and check to make sure that nothing got behind the linkage . Now ya may have to use a hammer and long drift punch to tap it back and then remove the valve and disassembal to see what has happned . Best to have a book tosee what your dealing with here if you have never been in one before.
