Re: Super M
Posted by A. Bohemian on April 15, 2007 at 09:37:20 from (207.170.88.120):
In Reply to: Super M posted by Jeff McBride on April 14, 2007 at 20:10:40:
I must say, the problem sounds to me like inadequate compression on one cylinder. But your compression readings look good... Start by checking the governor. It only takes a second. If the governor checks out ok, try the following. Bad rings will often check good on a compression test and fail under load. Try a leak-down test. Use an air-pressure guage to see how quickly the compression leaks down. If it happens noticeably faster on one cylinder than the others, you may have found your problem. I also note you installed an electronic ignition. If I read your post correctly, this was done AFTER the rebuild and you've never heard this tractor run correctly with this ignition. New electronics can be bad out of the box. If the leakdown test doesn't find anything, you can try replacing the electronic ignition with original parts or a different electronic ignition; I would prefer the original system, but that is a personal preference based on my own experiences.
- Re: Super M Jason Simmerman 20:05:37 04/15/07
(0)
- P. S. A.Bohemain 09:40:45 04/15/07
(1)
- P.P. S. A. Bohemain 09:43:56 04/15/07
(0)
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
