Re: Farmall H leaks fuel
Posted by gene bender on April 25, 2007 at 09:13:20 from (67.55.226.214):
In Reply to: Farmall H leaks fuel posted by Neil Fuller 2 on April 25, 2007 at 07:59:50:
If you have a good gasket there should be no gas leak as the vaccum will pull the vaporized mixture to the cycls. Are you sure that the wetness you see isnt condensation as all carbs will get wet in a high humidity condition and if the temp is rite it will show as frost this is normall as carbs have done it since their begining.
