Farmall H leaks fuel
Posted by Neil Fuller 2 on April 25, 2007 at 07:59:50 from (168.170.46.5):
I have a farmall H and I just replaced the old high compression manifold with the regular gasoline manifold. My problem is that where the carb connects to the bottom of the manifold it is leaking gas when I run it. I had to use small diameter bolts to accomodate the new manifold versus the old one which had threaded studs on it. It's kind of a pain in the butt tightening the nut on the inside because there is no room.
