Am I MIssing Something?
Posted by A. Bohemian on April 26, 2007 at 14:11:54 from (207.170.88.252):
In Reply to: Noisy Farmall Super A Transmission posted by Bob McConkey on April 26, 2007 at 13:10:04:
If I may ask, what do you all see in his description that rules out normal gear noise?
You are getting excellent advice here, Bob. Everyone is right about the need for a manual and your ability to do the job.
(Unfortunately, they are also right about the expense!)
But again, a low-pitched, rumbling whine that decreases in volume when going downhill or not under load, and increases in pitch as you speed up can be a NORMAL noise! It certainly seems to me that this is what you are describing.
On the other hand, high-pitched squealing, chattering, and loud, rhythmic clunking are BAD noises that need diagnosis.
PLEASE have someone with experience listen to the noise before you begin dismantling things!
