Re: 986 Electrical Problems
Posted by dwag on April 27, 2007 at 17:17:58 from (64.6.1.210):
In Reply to: 986 Electrical Problems posted by CGH_Ben on April 27, 2007 at 15:21:28:
Trickle chg batt"s overnight and check voltage. Must have 12+ volts at batt"s and same at alt. Also feel batt"s after charging, if one is warm, batt is shorted internaly, same for alt. #2 (right spade) terminal on top of alt should have elec\hot all the time while #1 terminal(left spade) "hot" only when key is on. An alt should put out 14+ volts with fully chgd batt"s.
