I.T.Cub:reverse polarity?
Posted by Darlin on April 28, 2007 at 15:00:23 from (66.61.32.99):
I went to take the battery out to replace it with a new one and noticed it had been hooked up with the ground cable hooked onto the positive post on the battery and the positive cable hooked onto the negative post on the battery. A friend said it may have reverse polarity. He said it would have burnt it up if it was hooked up wrong. Is this true? I had been having trouble with starting it up and keeping it running. Would this have anything to do with it? Is it safe to hook it up the way it was?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
