Re: I.T.Cub:reverse polarity?
Posted by El Toro on April 28, 2007 at 17:04:09 from (205.188.116.138):
In Reply to: I.T.Cub:reverse polarity? posted by Darlin on April 28, 2007 at 15:00:23:
If it's a 6 volt battery it was connected correctly with the battery being positive grounded. You need the check the charging voltage at the battery using a volt meter set on
dc volts. Run the engine at 3/4 throttle and your voltage should be around 7.0-7.25 volts.
Hal
